Strong Odor After Delete
rcr1978
790
Spring Creek, NV
Turning up the idle fuel pressure to 60mpa and getting the vains closed up to give it a little more air helps a ton, I found the LML raw diesel smell was the worst out of all of them maybe to help the cat light of quicker who knows? Downside to higher fuel pressure is it's noisier but I will take that over coughing, burning eyes, and choking anyday :D
Blackmax123
683
central Pennsylvania
Just a guess but maybe the odor from the lml is worst then the other due to the cp4 vs the cp3. Anybody have a deleted and cp3 swapped lml have any issues with the odor?
This spring I plan on cp3 swapping and deleting my lml tow pig.
S Phinney
4,008
Quncy, Fl
This odor has to do with there is more fuel at hand. Even though it has the smallest nozzle flow it happens to have the most available fuel on hand because it returns much less fuel than the others. Stock pulse is greater in those idle areas as well. Mine probably resembles how a oversized injector lb7 would smell. It definitely does not burn the eyes but does smell stronger than any other stock version.
