strange 1st-2nd shift
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
I've been running Rob's 110hp tune on my LMM. Changed from a 70-80hp tune to Robs 110 and did the relearn. light and medium throttle shifts are spot on. Clicks through the gears perfectly. The weird part is at wide open throttle. If you roll along about 5mph and hit WOT the truck will go to shift into second and shut down. Feels like it makes the shift but drops all power, let off and get on it again and it takes off as if nothing happened. No codes. pulls great through 2nd, feels strange in 3rd (feels like you loose some accelleration and may be revving a little high) and then hits 4th perfectly and pulls hard again. Can't tell you about 5th and 6th, I don't pound it shifting into those gears. The TCM has not been changed, all stock shift points.
The only current mod to the tranny is the transgo jr kit. What do I need to be looking at in the ECM or TCM to get these shifts a little better? Any advice is appreciated.
Russ
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
I think your experiencing the truck defueling between shifts, which is saving your trans from slipping.
Mike L.
15,681
232
Fullerton CA
I totaly agree. Problem is; it still does a lot of damage to C3's even with the engine shut down. Need more trans.:D
coker6303
Aug 6, 2009
2,484
40
Houston, TX
one of these days Mike!! LOL
When it shuts down shifting from 1st to 2nd, I have yet to keep my foot on the floor. I let out and then get back in it. Guess I need to stay in it just to make sure it is the defuel....or we'll be building a tranny sooner than expected!!:D
The Neens
BFD
4,596
Monrovia, Ca.
I totally agree:D
dwax
Jul 21, 2009
127
mine did the same thing (exactly) the first time i tune it with efi. turns out my old ppe was still hung in my computer somehow, so i reflashed the ecm, tuned it again, and then it shifted great... at the time my only tranny upgrades were transgo and T.C.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I have flashed it 3 times with the same program to be sure that everything is right. Might do it again just for grins. :thumb:
Aren't the defuels in the TCM? That would mean the truck should still have the same defuel as before since I did not change the TCM tune right? All I did was pull 1 EFILive tune off the ECU and replace it with Rob's tune.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Possible torque managment kicking in. I wouldn't worry about it until you get your trans upgraded.
The Neens
BFD
4,596
Monrovia, Ca.
I'd give Rob a call, I'm sure he can make an adjustment to help you out...The 1st "big" tune I put in my LBZ acted this way, until it got some tweaking...
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Are you hammmering down in Track/Haul ass mode? or just in overdrive? I'm gueing your TCm has got used to shifting in O/D if taht's the case it will take a bit to figure out the shift point's to shift in/.Most people put it inTH mode to hammer downa nmd only use that switch for getiin on it it
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I'll give Rob a ring this evening and pick his brain. ;)
On the bright side, Rob's 110hp tune is friggin amazing! Very friendly around town and in traffic, very responsive but not explosive until WOT. Beats the crap out of my 80hp tune I was running before. :thumb:
coker6303
Aug 6, 2009
2,484
40
Houston, TX
UPDATE
IdahoRob fixed the problem, just a slight change in the tune fixed everything up. Shifts spot on!
Here's a mechanical problem that is developing. After I let the truck sit with the engine off for a couple of hours during the day or overnight (and I let my truck idle before driving) the light-mid shifts are drawn out. The engine revs a couple hundred rpms between shifts instead of snapping to the next gear like it should. It goes away after it is driven for a mile or so.
Here's the best I can explain it: apply light throttle revving to 2200rpms and the shift from 1-2 is triggered, the engine free revs (no trans resistance) an additional 200rpms to 2400 before pulling down into 2nd gear. It will do this whether you are in tow haul or normal. TCM tune is stock.
Again, it only seems to do this after the truck has set for a while. I'm going change the tranmission fluid again (changed 12000 miles ago with Amsoil). Truck has 37000 miles on it.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
logged 4 passes at WOT, during 3rd gear the revs are around 3400 rpms and trans slip rpms are up to 800. Remaining at WOT, it has no problem shifting and locking the converter (+/- 8rpms) in 4th gear. 1-2nd shifts are great, but 2-3 and while in 3rd something strange is going on.
any ideas
The Neens
BFD
4,596
Monrovia, Ca.
both rolling around 5mph and from a stand still, no boosted launches.
When my '07 had a stock trans, boosted launches really exposed the 1-2 and 2-3 shifting problem...Rolling into the throttle, it seemed ok...Now, the ECM and TCM tunes have been modded, so it shifts well in any situation...
coker6303
Aug 6, 2009
2,484
40
Houston, TX
i'm trying different tunes right now. I'm at a loss, confused trying to figure this out.
I remember with the quadzilla tunes boosted launches shifted great, it was the mid throttle shifts that were odd.
coker6303
Aug 6, 2009
2,484
40
Houston, TX
alright, now with the quadzilla 90hp tune it is going to the rev limiter in 1st and shifting, bounching off the rev limiter in 2nd before shiting into 3rd but the converter is lockingup in 3rd again.
Is it possible I am getting a bad VSS reading at the transmission? I can't get my MPH to register when I am logging the TCM.
