Stock motor times.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Throw in how many passes at that time until a failure and what failed, if you guys dont mind posting :hug:
quinton
1,883
Granbury Tx.
I wish I could just get in the 12's with my setup!!! Very aggravating seeing people with stock turbo and tranny runnin better times than me.
quinton
1,883
Granbury Tx.
Built trans, lift pump, Danville 68 mm turbo with billet wheel, head studs, fuel rail plug, Lbz mouth piece with 5" intake, straight centerlink, tie rod sleeves, Ppe manifolds an up pipes. Dsp5 from ATPtrucks. Runnin nitto 420's 305/55/20 from what I've read and everything I should be mid 12's. I hold rail pressure so idk what it is. I'm gonna log it tomorrow agian to see what it does
bcdeutsch731
619
13
41
Illinois
Ran a best of 10.6@126 with stock motor, Danville 68mm/S480, lbz mod pump, 50% inj. I had over 100 runs in the 11's with a single 68mm. Put the twins on it and had over 75 runs with a race weight of 5100 lbs. I put about 2000-3000 miles on it. I tried for that 10.5 and bent all of my rods. Three of them were bent so bad the pistons would hit the crank.
