I would only be guessing, that he used the original to make a cast mold. From the crease seen at the bend, in Mikes pic above, the detail of the part looks identical to stock.
I will have to go get some pressure drop numbers to see what this restriction is really doing. From just measuring, the x-section goes from 8.3 in^2 to 5.3 in^2 (where there is a 90 degree razor sharp bend) then to 6.6 in^2.
For guys doing series twins, assuming 35 psi of boost, 4000 rpm, air flow is something like 1160 cfm. That restriction is flowing air at 360 mph around that 90 degree bend. Add the lack of (any) curvature to the inside of the turn, and that is going to be some serious drag.
