stock injectors s400
jliddle
Jun 30, 2012
331
NC
Anything over 72 should be a 87mm I believe.
I'm going to try a 67/83/.90. Stock injectors with stock pump. 1053 is what's in my trans now.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I ran a s475 on stock sticks for some time, it responded well for being stock fueling. But I was at 2600us the whole time otherwise it was a lazy pig.
paint94979
Beer Nazi
Sep 18, 2006
11,715
What kind of drive pressure, and boost pressure do you run paint? 83 turbine is pretty small for a 75mm compressor....
No idea. 3300uS and my EGT's don't touch 1400* at the end of the track. From the 60' on my truck runs 100% clean
Josh154
1,220
85
Sioux Falls SD
Dam that's awesome, makes me not so worried. It's a Lly though? I'm about to swap turbos and want to be 600 on stock sticks.
Josh154
1,220
85
Sioux Falls SD
I'm doing a modded Lly charger with a tct wheel, high flow vanes, 10 blade turbine with a port n polish. I'm doing tow flows at the same time and a egr delete. I'm hoping for 600hp. I know right now I'm at 3000-3100us max effort. Think I should have Kory bump it up a little more?
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Well, I'm saying I wouldn't try increasing it any more.
Josh154
1,220
85
Sioux Falls SD
What's the difference between lbz and lmm? I thought I remember reading one was 7 hole and one was 8 hole on the nozzles. Do they flow the same amount in stock form?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Well my truck is running pretty good spoiling wise imo. Haven't touched Ecm yet, about 3/4 way through tcm tuning it's not bad atall on stock fuel
