Stock fuel, stock engine, what turbo?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Its too big. One thats properly set up that is. A machined S483 will greatly outflow the box S510. I happen to know a guy that does killer work on turbos, so I'll be using his S483.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Not to argue because it would be cool if i was wrong but your saying your S483 is going to flow over 160 lbs per minute ? I'll have to see it to believe it , not to mention the turbine side on the S510 will flow a whole bunch more than an S400 ever will , not saying the S510 is the right turbo for what you want , but that's a pretty bold claim to make hell even a GT5533 is -10 lbs a minute less than a S510 .
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
How does it spool compared to stock? Also how does it tow? Do you have to do allot of downshifting to keep egt's in check?
i knew a guy who towed a dmax from NC to FL with his 472 and it worked fine. another guy with stock fuel towed a dmax from NC to KY just fine. neither had to down shift any. unless on the grades and EGTS were not bad at all
13,765
834
I just did a google search for S510 compressor maps, and this is what I found.
Compared to a GT5533
I don't see where the Garrett is down in overall airflow.
TrentNell
Jul 7, 2008
7,543
slc tuah
It wasn't meant to be a bag on the GT5533 , it is an awesome charger just a comparison, the map in the 2010 airwerks catalog peaks at 160.
13,765
834
I didn't take it as a bag on the GT. I was just shocked when you said the BW flowed 10 lbs/min more. I googled to compare the maps, and I was a little confused when I compared the two maps. I didn't realize there was a new map. Thanks for posting it. Do you know if they changed something?
TrentNell
Jul 7, 2008
7,543
slc tuah
I have no clue Josh , and even at that I take maps to only about 90% truth
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Let me see if I can get the stats on the turbo. It uses a special turbine wheel (and compressor wheel for that matter) that flows much more than the out-of-the-box S483 would.
