Stock CP3 good enough?
pavetim
299
5
I am looking into buying a 2011 LML and been reading all the horror stories about the CP4. I see the kit that Fleece sells, I don't have $1800 for a kit but i have seen some CP3s even refurbished on ebay for like 3-400. Would their conversion kit with a stock cp3 be fine? I actually plan on getting a FASS lift pump to make the CP4 last a little while longer anyways then upgrade to the cp3.
slowlml
Undercover Epa agent
Feb 6, 2015
577
53
Strasburg Va/Wardensville Wv
If your not looking to make big power a stock lbz cp3 will do just fine. They'll support mid to high 600s if healthy. Don't know much about the eBay cp3s tho so it's a shot in the dark on that one.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
DO NOT BUY FUEL PARTS FROM EBAY!!!!!!!!!!
I cannot stress that enough.. Find a Bosch dealer and get a new lbz pump from them
13,712
773
This post times 1 million! Fuel system is not the place to be cheaping out.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Also keep in mind ANY CP3 that has had fuel run through it and removed is now considered a core. WAY to many have bought good running CP3's that were removed, but sat for a few months, then seized up because some moisture got into the CP3 or debris, and it caused a BIG mess. So any used CP3 should be considered a core for most purposes.
pavetim
299
5
hate to cheap out but i didn't expect to spend $40000 on a truck and have to immediately put $2000 into it. I am only going to use it for towing a 15,000 5er, and im going to get a mild street tune from Idaho Rob probably 110hp at the wheels. I think after a bunch of reading i'm gonna stick with the CP4 and get a FASS titanium lift pump. What you guys think? Oh and will use lubricant every tank.
Dozerboy
4,892
470
TX of course
No body says you have to do it right away.
That's the bad thing about the Internet all you see are the guys that have problems. Not the majority that don't have issues.
slowlml
Feb 6, 2015
577
53
You'll probably be fine with the lift pump and running, say optilube in every tank. I agree with what dozer boy said. For every 10 lmls you read about that have had a cp4 fail theyre 100s more that haven't.
