stock Alli with twins?
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
how long would a stock allison last after installing twins if you dont program it hot or drive hard and only daily drive with it:confused:
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
thought so whats the cheapest thing you could do to make it hold up with twins? and makes a good clutch kit or trans?
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
You could put twins on with a stock trans, but there is no point in doing it. Pretty much if a tune is safe for a stock trans you shouldn't have EGT problems and if you are wanting twins for nasty power, you'll need a trans anyways.
bondurch
Jan 30, 2010
It would last for years if you did not want to unleash the twins, but why buy twins if you did not want to unleash the fury.
Thinking about it you would have the smoothest accelerating stock truck in your town.
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
I couldn't justify fixing something that wasn't broke (to the wife anyways) so I did the twins first. Finished late on a Sunday and took it easy on Monday, limped it Tuesday afternoon. However, that was in November and I have been driving it easy everyday since. I should finish the build on a spare core I had this week (still driving stock trans). Going to be a fun spring though! :thumb:
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
i cant remember were but i saw a link somewhere on this forum a place that makes a stage 1 Alli that holds 600hp and there stage 2 holds 800hp. does anyone know where or what im talking about?
Sledhead
Nov 29, 2008
884
BC
I suggest calling Mike L, Trent (EPR) , George (Big Dipper) or any others on here to fix you up depending on your location.
pmeg1
May 28, 2008
76
I can honestly say that I have over 30k on a 500 rwhp tune from Idaho Rob on MPI twins with only a transgo JR and a Goerend converter on my 06 LBZ. I did buy a core to build sometime this summer though. It never leaves that tune, tows up to a gross of 25K and I'm not easy on it. I beat it like a rented mule.
Sledhead
Nov 29, 2008
884
BC
A Transgo Jr on a LBZ helps.
Us 5 speed guys need to pull it all apart to put the full kit in then you're into like I am tonight;
Sledhead
Nov 29, 2008
884
BC
Done for the night, drum has turned the corner.
Jetty, IMHO get your twins and do something to the trans and have fun.
Especially the last part. :spit::woott::spit:
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
Twins before trans = scorched C3's and C4's. I had a Transgo jr. installed and it never limped but this is what it looked like when I opened it up a month later. The C1's, C2's and C5's looked like new. This was on Rob's street tune only. 1st and 2nd pic are C3's and the third is C4.
Jetty LBZ
work in progress
Jan 24, 2011
404
33
middle TN
thanks man i may wait tell i have everything need bought then install it all at once :thumb:
