Kory do you have another OS for an 02 ZF6 truck?
When I use the 6006 I lose control of my HVAC. It wouldn't switch between defrost and vents, and AC light was stuck on. My 4wd light also wasn't working, but the truck was going into 4wd.
What are your thoughts?
The software allows for segment swaps, I have had good luck with gas tank swaps, but sometimes with other segment swaps it has caused weird issues.
Do not even attempt a system segment swap on an LLY.........
If you need something specific I can email it
I'm looking for these two oem tunes:If you need something let me know, most likely I have every OS ever released by GM
So on the calibration window, do I need to change the code in the BCC box? The old tune code is DPJK and the 6006 tune from Kory is DRUJ.
You have the wrong system segment is why those features stopped working.
When I beta tested the 2001-2002 OS conversions back in 2006 with Ross ,I/We tried all different combinations of full flashes and I started doing all 2001 OS swaps to 2002 way back in 2006 and what I discovered was the biggest issue with OS swaps is to make sure the correct system segment is used.
There are 2wd, 4wd with ZF6/manual transfer case, 4wd with Allison/manual transfer case, 4wd with Allison/push button transfer case.
Then there is Auto HVAC and manual Hvac, no cruise control and cruise control.
Many tuners will make the mistake of assuming that just a simple OS Swap is all you need, that is never the case.
Do not even attempt a system segment swap on an LLY.........![]()
I've done a couple LLY segment swaps and had good luck so far. I've also done some LBZ segment swaps for the DURABURB tunes I have done, and they worked out good as well(just wished I would have had a cab and chassis instead of a 4500 MD tune for the dual tank segment).
The segment numbers is what makes a tuen file what it is...
