How did you get the one speaker to work?
No clue,I was hoping you could tell me:rofl:
The volume on the deck is max and i can barely here it coming out of the 1 speaker
the gain on the amp doesnt help
Yes, you can still show 12 volts between power and ground. However, the remote wire from the head unit tells the amp to turn on.
Looks like the remote wire is working correctly.
You said you were going to hook up the front speakers to the amp but hadn't done it yet. Try hooking the rear speakers up to the front channels (channels 1 and 2). Make sure you also move the rear RCA cables to the front channels. See what this does for you.
Did you check to make sure the fader and balance are at 0 or ----? Yes i fooled aroung with all that stuff
well i hooked up the front speakers and same thing.....very lilttle sound coming out
only one has the wires on the back ??? lol
or what??
Are you using the rear channels (3 and 4) to run the front speakers or the front channels (1 and 2)?
im coming off the amp l/r channel 2 for the front and channel 1 for the rear
kind of odd way of labellings on the amp it is a 4 channel but they use just "A" & "B"
so you have Channel "B" for the Front? and Channel "A" for the back? and making sure not to bridge them?
Check the high pass/low pass filter switch that is next to the gain and make sure both channels are set to high pass. Also turn the gain up and down again to see if it varies now that you have the front speakers connected.
