LMM: Steering gear box
blue09dmaxx
Too broke for this shit
Jan 15, 2012
823
The south
Input shaft seal on my steering gear box is pouring when it's cold. Are these things serviceable with new seals or do I need a new box? Whose done one and give insight on this? Anybody have a good one laying around from a truck they parted out?
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Bump for ya, which steering gear is it.? GM made some changes in 2007+ NBS and I do know the 2500HD gassers went to a 670 or 680 gear box(owned one prior to my Dmax) just not sure about the Dmax NBS.
CarolinaHD
969
NC
Gm reman box's are junk! Mine has about 3" of play before the wheels actually start to turn and still leaks like a bitch. Rebuild the one you have or find an oem junkyard replacment.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
Ive started to rebuild them with new bearings and seals. I can get new hard parts too if needed but it starts to get pretty expensive quickly then. For example, a sector shaft is $105.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I scoured craigslist a couple years ago and found one from a 100,000 mile 2500HD ($50.00) to send to Benchworksteering.com here in town when/if mine starts leaking. I had him rebuild the one on my 1982 8 years ago, he invited me to look around his modest 1500 sq. ft. shop, clean, neat and everything in it's place. He also has the ability and parts to rebuild my Hein-Werner floor jacks....:thumb:
fastpunker
adrenaline junkie
Feb 7, 2012
215
Lake Havasu City, AZ
are the redhead boxes new or are they just better rebuilds?
I am interested in this, I have the same problem with mine... temps drop below 50 something and it starts to leak out the input shaft seal.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
They are junk. Nobody can rebuild a box even close to how they were new. The best and only option I would go is a low mile factory original junkyard box.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
They are better, rebuilt to closer specs than stock and some bushings replaced with needle bearings. I just installed one on a dodge and it steers like a brand new truck!
bml2200
256
IL
I put a Redhead steering box in my LBZ 2 months ago. So far it's been working well, no leaks, a lot tighter than the one it replaced.
Ridin'GMC
I like red
May 20, 2010
636
20
MA
I've had my redhead gear box for 6 months now. It's already been through some abuse from 4wheeling and constant hard corners everyday. So far they are holding up pretty well, better than any gearbox I've replaced which is my 3rd set in 60k miles. They are definitely an improvement, steering is tight as it should be. 37's kill gearbox fast and mine is holding up. Although it's time for me to upgrade the power steering pump
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I helped Pep put one in his 01, and that thing drove like brand new. Even with all the miles on his truck, the redhead box made it drive like a new truck. I plan on putting one in my BURB here REAL soon.
MaxD
Jul 4, 2012
I have had a Redhead steering box in my LBZ for a couple of years now and it still steers better than when it was new. I would definitely recommend them.
