my 2001 seems like i gotta crank it about twice as long to start vs. newer diesels... is this just the lb7?
kinda freaked out by horro stories i been reading about lb7 head issues. i bought this truck in may 09 at 126,000 miles and since i have replaced water pump, driver side hub, belt tensioner, and now the radiator is leaking from in the fins somewhere about a gallon a day!!!!!!!!!
My LB7 was a b**ch to start in the winter. Although I think a few of my glow plugs went bad so that could have been part of the problem.
My LBZ has never flinched starting, even down to -30 with no block heater and it sat for 18 hours like that.
If my LB7 sat outside for more than 5 hours in 10 degree weather I'd have to cycle the glow plugs and crank it over for 4-5 seconds and it wouldn't stay running a couple times. I ran fuel additives so I don't think I had gelling issues.My experience with my LB7 and LBZ is also exactly like yours.
The coldest it has been for me with the DURAMAX starting has been 41 one morning, and it fired right up like it was 90 outside and ran smooth as can be. If you want to see one buck and run like crap cold, find a 6.5 with high milage injectors and some bad glow plugs. My old 6.5 even with new glow plugs would take 18-20 seconds of glow time on the plugs to get it to even try and start when it was 45 outside. The one morning it was cold here I about gave up on it as it fogged out my whole yard and wouldn't hardly fire, and when it did I thought a rod had come out of it.
