Starter Drag
wilsondiesel
190
Sedalia, MO
Hadn't had this happen before, have a lb7 that the stater solenoid is engaging but starter won't go ahead and turn over, until about the 4th try of the key cycle. Voltage is good down at the starter and solenoid/exciter wire, had starter bench tested and it tested good. Even went ahead and tried a new starter and it does the same thing. Ring gear looks okay on the flywheel, any other ideas?
3,729
297
Have you put a wrench on the balancer bolt and made sure the motor is easy to spin after sitting? I had a cracked head and it did something similar because it was hydrolocking.
Sent from my E5823 using Tapatalk
aashton1206
172
You have efi live?
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, custom tuning on v2 by Rick Fletes, 33x12.5 nittos at on 20 inch American steal wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, Custom Y Bridge.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Mine (LLY) did that too. Found out the bolt that ties the two + battery terminals together was loose. You could also have a bad ground somewhere. Try clamping the starter case to a good clean ground point with a jumper cable and see if it makes a difference.
