Batteries were 4 years old, the truck would lose the charge over time. The passenger battery always gets a bath of water/washer fluid from the windshield. It had over flowed the battery a couple times because the battery tray is rusted and it dripped down onto my stainless mud flap and stained it. I drained solution, parked the truck for a couple months. Winter came, and i went to go start my truck and it was dead. I went to boost the truck and it wouldnt even start with a boost. I left the tractor connected to the truck to try charge the batteries. It eventually did start. Drove it up to my shop and i discovered that the passenger battery had froze and split open.
Installed two new batteries, cleaned battery cables, charged the batteries. Left the truck hooked up to the trickle charger over night, plugged in the block heater as well.
Next morning went out to start my truck and move it because we were suppose to get some snow and i didnt want drifts in the yard. And the truck wouldn't start. Brand new batteries, on the charger all night, clean cables.
Good my battery charger with the engine start 300amp start. Hooked it up, let it sit for a couple seconds, tried the key, and the starter just clicks, it turns the engine over a little bit but cannot overcome the compression. So it just goes a dull click click click click.
My truck has 477 on the clock so i figured it would be the starter. So i got a new starter, put the starter on and cleaned the grounds on the passenger side of the block. Went to start it back up and the same thing. dull click click click.
I have tried to jump the ground from the battery to the engine, the frame, and one from the positive battery cable to the battery. Even then it just clicks.
It eventually started, but rough. Which is very uncommon for my truck, it starts in -40 no problem and chugs a little bit but clears up right away.
Anyways, after becoming the definition of insanity, trying the same things over and over and expecting a different result it started... And the engine light was on, Glow plug circuits 1 through 4 are all triggering codes, these glow plugs have less then 100,00 on them. p0671 p0672 p0673 p0674
Is there a ground that is hidden that i did not see? Or is there something else i am missing?
