No trans is working perfectly I can load it up against the brake and it will break the tires loose . I just unhooked the edge cts2 and hooked up my flash scan v3 and it says there is a current code of p0880 ?bound up torque converter?
Thank you I did that last night . Going to put a new ground from motor to batteries. Also changing the ignition today being intermittent I’m hoping that’s itAttached. Looks like a power or ground problem. TCM detects power loss from battery supply at ignition off. Check your harnesses, grounding, and TCM connections.
Thank you for the info . I’m trying to track down a factory electrical service manualThank you I did that last night . Going to put a new ground from motor to batteries. Also changing the ignition today being intermittent I’m hoping that’s it
Thank you ! Great reference wish I had the test equipment I need . Still chasing stalling when I put it in gear and go to take off it stalls .
Not setting a code when it does it . I think I got the p0880 to stop . I’ll run it tomorrow and double checkThank you ! Great reference wish I had the test equipment I need . Still chasing stalling when I put it in gear and go to take off it stalls .
Yes fuel rail pressure is good I can hook a mechanical gauge on the lift pump . I’m not having any issues with performance after I accelerate runs perfect . Shifts through the gears and hauls ass ! It’s just the log idle stallare you able to read fuel pressure?
No the neutral safety switch on the trans fixed that issue .Are you still getting the "shift range inhibited"? Points to the trans electricals.
Yes fuel rail pressure is good I can hook a mechanical gauge on the lift pump . I’m not having any issues with performance after I accelerate runs perfect . Shifts through the gears and hauls ass ! It’s just the off idle stall
Yes fuel rail pressure is good I can hook a mechanical gauge on the lift pump I suppose . I’m not having any issues with performance after I accelerate and if it doesn’t stall it runs perfect . Shifts through the gears and hauls ass ! It’s just the off idle stall
