Stage 4 verses Stage 5 Whats the difference
Vasbinder
282
Floresville, Texas
What is the difference between the two kits other than holding more power. Will a stage 5 kit last longer than a stage 4 kit if both ran the same power level like 600 horse? Is it better to spend the extra money and get the stage 5 or is it to much tranny if your not going to use it to it's full benifit? I always wondered about that. Thanks for any input
maine04max
Dec 11, 2008
1,009
if your talking kits , I assume your talking PPE . as far as which to choose , I would go the bigger kit . it holds more power and is only a little more
GeorgiaDieselGTO
Wants to drive his truck
May 12, 2010
102
Crossville
The stage 4 from PPE is basically just a drop in set of clutches with thinner steels and such that will let you slip extra clutches into the packs. It comes with the transgo, knockdown valve, increase washer, and c2 piston kit, along with the full set of clutches.
The stage 5 kit comes with all of the above plus some cut pistons and revised plates that will give room for more clutches than the stage four.
obviously each builder has his tricks that will increase longivity and holding power. :)
15,681
I would do a video on how to build an Alli with a LOT of tricks contained in it. The problem is I would sell 2 maybe 3 DVD's and the rest of the country would have the info. You guys would share them and pass them around, probably for money.:rofl:
I'll leave the '01/'10 Alli to everyone else. I am concentrating on the '11. There are things to be learned from it and can be incorporated in the earlier Alli's.
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
i have been tempted to do my own but the last 2 i did th350 and 700r4 both failed soo im not too sure but both had a previous problem
durallymax
Apr 26, 2008
2,756
Under The Hood
That's what I understand, but some people say there are some "super duper secret mods" done on the 5 that cause it to hold more power...:rolleyes:
Every trans has super duper secret mods just depends on the beuilder
This thread is funny. :D I guess I've been fooling everyone for a long time.
Basically haha
So you care to share your wisdom Sheep Master Mike?
If you get on his good side.
