Question: Stacking ( modules and tuners)
speedmetal6.6
Dodge Destroyer
Nov 3, 2008
252
Gillette,Wyoming
Hello , I've got a question about stacking.Some say its fine and some say its the worst thing you can do.Whats the deal? I've got a friend that stacks an edge with attitude with a PPE hot + 2 and scrambled his tranny in about a 1/2 hour, he has since fixed the tranz and I think he stacks a Quadzilla sometimes too!!! and another guy had to replace his injectors and the pump.Any how I'm thinking of getting a duramaximizer, and I'll probably use them seperately but was wondering if I was asking for trouble if I stack them. P.S. does the maximizer make the truck run good, I mean I know the Hp levels arent as much as the xcelerator tuner but does it run smoother or the same.:D
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
I did that stack several years ago, edge and ppe hot, I also had the ppe boost controller inthe mix.............it worked ok, I never tried the duramaximizer though.
Noreaster
2,910
Cape Cod,MA
Can't stack 2 plugin programmers at the same time like the PPE & Quad
Stacking was an easy fix for removing the speed limiter, no hi boost codes & making 450hp or more at the time.
ripmf666
15,123
14
47
Wentzville Mo
He does not have Efi Live just the PPE tuner
He is asking about running this tuner link http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_35_47&products_id=129
With the Duramaximizer link http://www.pacificp.com/store/index.php?main_page=product_info&cPath=2_14&products_id=6
Product Description:
The Duramaximizer was specifically designed for 2001 through 2006 Duramax diesel engines and provides up to 100 horsepower and 180 ft.-lbs. of torque with the turn of an “infinitely” adjustable knob, load sensing for smoke-free operation and maintenance of exhaust gas temperatures (EGTs) within manufacturer tolerances and decreases unnecessary transmission downshifting while towing.
With a sophisticated processor sealed in a billet aluminum cover, the Duramaximizer provides maximum power without altering the factory PCM, internal components or exhaust system.
For more horsepower, use the Duramaximizer in conjunction with a Xcelerator programmer.
