Spring clamp bolt size?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I cut 4 2x4.5x3/4 inch peice's of steel out the other day to use for spring clamp's.... Just wondering what diameter bolt everyone is using, I'd like to use 1/2 in but that will leave only 1/4 inch on each side of the clamps.... Now granted that should be strong enough with a washer and grade 8 setup still, but maybe I'd be better off using a 3/8th??
To make this easy to answer I guess, What diameter bolt do yall have, and how much material do you have left on the end's?
Thank's
SDP
AKA Dmax15
Dec 20, 2008
261
Port Angeles, WA
Mine are either 3/8 or 1/2 but I can't remember which. Here is a pic though if it helps.
jraymer
<--Tree Hugger
Oct 31, 2008
1,421
Las Vegas, NV
Mine are 1/2" by 4" we had to squeeze the spring with a c-clamp a bit to get the bolts to reach but it worked out well.
Dozerboy
4,896
474
TX of course
I'm good with 1/2" Ubolts and only 1/4" plate (hey its what I had). I get nasty axle wrap at the beach too. I don't have then on the front and back of the spring packs though since they stay on all the time.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Got mine put on with 5 incher's.... Man does it right awesome!!! I'm gonna pull them both off again and drill and tap for a 5/16 bolt right in the middle of the bottom side stock's. Then put them back on and use that hole I made as templete to drill and small pilot hole, then take the stock back off and finish out that pilot hole to be a 1/4 in deep 5/16 hole... I picked up some 5/16x1 in bolt's at work so when that's all done I shouldn't have any trouble with them sliding back toward's the axle..
Ohh and I'm pretty sure I've the biggest clamp's around 3/4 inch!!! SWEET lol
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Got mine put on with 5 incher's.... Man does it right awesome!!! I'm gonna pull them both off again and drill and tap for a 5/16 bolt right in the middle of the bottom side stock's. Then put them back on and use that hole I made as templete to drill and small pilot hole, then take the stock back off and finish out that pilot hole to be a 1/4 in deep 5/16 hole... I picked up some 5/16x1 in bolt's at work so when that's all done I shouldn't have any trouble with them sliding back toward's the axle..Ohh and I'm pretty sure I've the biggest clamp's around 3/4 inch!!! SWEET lol
Shouldn't be anyway. Mine rode on my 03 for about a year and on this truck for the last 7 months and never moved. Crank them down tight and they wont move.
