I cut 4 2x4.5x3/4 inch peice's of steel out the other day to use for spring clamp's.... Just wondering what diameter bolt everyone is using, I'd like to use 1/2 in but that will leave only 1/4 inch on each side of the clamps.... Now granted that should be strong enough with a washer and grade 8 setup still, but maybe I'd be better off using a 3/8th??
To make this easy to answer I guess, What diameter bolt do yall have, and how much material do you have left on the end's?
Thank's
Thank's
