spot check of the mpgs
3,733
305
Rain and too humid not to run the A/C.
X2
My A/C is always on. The only time it turns off is when the truck forces it off (below 43 degrees outside, IIRC). I can't really tell a difference in mileage on the Duramax with it on/off, and I like the drier air coming out of the vents.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
used about 27 gallons of water for the ENTIRE round trip.
Like I said, bed was too full to check the level when I dropped the trailer in Buffalo.
jon5212
Oct 13, 2010
119
So if we just cut it 50/50 you possibly burned 13.5 gallons of water/meth on the return trip, cut at 20% methanol is about 3 gallons of methanol.
So really you burned almost 23 gallons of "fuel." Just adding the methanol+ diesel there so that knocks it down to 22 mpg or am I missing something here?
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Sounds reasonable except I was spraying with a 175 ml nozzle and higher psi while towing.
I'll run straight water next if the temps stay up.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I'm gonna get flamed for this one I know, but here it goes .
I just drove 230 miles across flat Michigan and Ontario doing no more than 60 mph
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Drug this thing out to St Thomas Ontario:
28 ft, 4800lb
unhooked from that, topped off the factory tank and the 7 gallon meth tank and hit the 402.
aux tank was Empty. So truck was about as light as its going to get. Aux tank gauge is 3rd from the left
Start odometer:
Start engine hours:
The route:
on 4 in between the 401 and 402 is an Airstream Dealer. Topped off the tank and took pics in their parking lot. North on 4, west on 402 to the US/Canada Border. 5 minutes idleing in line at customs and I'm out of the gate headed east on 69 to Flint. Stopped at Starbucks on Miller Rd in Flint to grab a coffee and meet up with a member on Duramax Forum. Out of there, back on 69 to 127 to 94 to Parma MI truck stop for diesel
Either I used all 7 gallons of water or it finally froze, because it stopped spraying about 2 miles before the truck stop. Air temp had dropped to 28 by then. I was 5 miles from home, the same site of my famous driveshaft incident, and its Friday and they sell beer. So I decided it was a good enough time to stop and fill up.
6.8 gallons of diesel
end odometer
end engine hours
end trip odometer
topped off:
some splashed out
and finish the day with a Sam Adams sampler pack :)
Listening to the weather channel on the CB, Canada station was saying winds out of the W/NW at 17 kph, back in the US the Weather Station said out of the NW @ 5 MPH
Colt
Jul 23, 2010
523
Run tire psi at 75 and set cruise at 60 mph with Brayden's tune for the job go up without meth and back with then show the log. I get best mpg like that without meth mix can't see that extra cost. LBZ puts out great mpg at 60 mph on mine with tires max'd for best rolling average. Almost 40k mi. on it now seems to be loose now on trips when you do put it down for comparing hill pulls or playing with those Prius rockets that want to show their battery power boost I guess. Dyno'd 475hp/840 tq. EFI tune so when I roll into it passing it's hardly any smoke runs clean on cruise speed settings up to 90 mph. I noticed alot better running truck after Raptor liftpump was put on then we tuned/dyno'd it.. Set the regulator at 20 psi from feeder line with gauge inline just before stock filter. Put the pencil to cruise/60 mpg best was 26 average 23 mpg just truck not towing elevations from 4k to 11k mtn. Interstate driven. Happy with this result on that size of truck. I'm sure others have beat this towing or whatever but ours was just the first test series.
3,733
305
33.8 MPG, that is CRAZY!
But how many times did you get flipped off for only doing 60?? :spit:
Seriously, though, I can believe that mileage; especially for a 2WD and stock size tires. It is very impressive nonetheless.
You are inspiring me to try for maximum mileage on my next trip home. Unlike you, though, I don't think I have the patience to go only 60 MPH. I'll give it a shot and see, though.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
I passed one semi the whole trip.
Although it caused severe brain damage going 60mph for 230 miles, I'm afraid i have to do it again to make sure it was/wasnt a fluke
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Here it is, round 3 - a dissapointing 25 mpgs:
:D
another Park Model:( going to PA
Dealer I delivered it to offers to deliver it and set up to the site. Guess most people dont have a vehicle big enough to tow these beasts.
Unhooked from the trailer and filled up. Here is the route:
Filled up at the Flying J, Hubbard Ohio
Even disconnected the fill line between the Aux tank and Factory tank to shut up the "you're cheating and pumping fuel" people. Sorry for the Crude-ity of the disconnect and cap off, electrical tape and zip ties was all I had on hand.
Start odometer, trip, and hours:
http://i873.photobucket.com/albums/ab291/lotsofmiles/Snapbucket/66BB6CBE-
End ODO, trip, hours, and fill-up info - feel free to compare time stamps on pics vs engine hours...;) and notice fuel line is still disconnected
looks like 25 on the dot to me
