I'm glad this has worked for you, but you are confirming my comment. Electronics do not like heat, in any way shape or form. Furthermore, the fuel temperature sensor is in fact in the return line, at least on my LB7 so that 150+ degrees you speak of is what you would be sending through the " cooling" port of the FICM, after it has been heated by the fuel lift pump, CP3, injectors ect. not ideal in my opinion. I believe that relocation away from soaking up heat from the engine and running dry is an option, however not an ideal one as the internal electronics are going to create heat on their own. I also believe that seperate liquid cooling is also an option, but this will need to be a large enough system to remove the heat created inside the box, as well as the heat soaked up from the engine. Ideally a guy would combine these two, relocate and liquid cool the unit, after all the cooler electronics run, the more efficiently they run, and this just might contribute to longer LB7 injector life...
SO.... isnt that what you said to do run the return outta the cp3 to the in then back out to the normal return? my truck with cover on doesnt get over 180 going 80 down the freeway an only gets to like 160-170 around town? with or with out cover? i can run my truck hard as hell my ficm is col to the touch with fuel flowing threw it first then to the pump.. Also what everyone say to much fuel pressure from the pump is? 15psi? i think mines runnign in the 10-15psi range have to get a gauge put in and see
again let me know how this works
I guess some questions are being answered slowly but surly
My point of this thread was this:
Many people relocate the FICM.
After relocation, does it need to be cooled???
If not then happy relocating...
The other concern is A) people running lift pumps, get the FICM leaking, and B) peopel want to bypass the fuel thru it for whatever reason.
Now...If you bypas sit, we go back to cooling? Does it need to be cooled? If so you cant use fuel now because you bypassed it. So will a standaone system work to do this?
Tonys idear was to use return fuel, I think its too hot but maybe not. If it is, again, would a stand alone system work? Be worth it?
The radiator has a oil cooler, trans cooler and in the winter we can completely block the front and not overheat the engine.
I havent been able to find any oil cooler in the radiator?
That is because it is on the drivers side of the block, that long tube off the water pump headed to the filter location.
I was thinking about a different set-up on the gassers.
My bad, but the oil is still cooled at the filter head.
