LMM: Sound Deadening Question
bartman432
Nov 4, 2011
242
When laying sound deadening material are people covering the two rear rectangular vents that are behind the rear bench seat?
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
You shouldn't cover those, they are for pressure equalization. If you do. more than likely, closing your doors properly will be extremely hard.
It also provides somewhere for the air to go when you turn on the AC/heat.
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Anything thats shuts like a ford door cant be good. There doors are very cheap sounding. I wouldnt want it. Lol but i think hes referring to it still shut easy with it covered.
1,868
The air in the cab has to go somewhere, thats what those vents are for. I wouldnt cover them.
bartman432
Nov 4, 2011
242
We got several no's and one yes for covering the vents. The only road noise I get is from those two vents. Other than that, my interior is definately quieter after laying sound deadening material.
bartman432
Nov 4, 2011
242
My GMC had them covered and the plastic housing was removed. Doors shut like a 08 ford :thumb:
Any issues with the air conditioning or heater working correctly, or pressure in the cab? What year was your GMC? Thanks for replying to this issue.
Harbin_22
3,858
Southern Indiana
I just did this, I did not cover them. Turn your heat or A/C on, close all the doors, and walk to the back of the Cab. There is some serious air being pushed out of those vents
