LB7: Something is still wrong
05chevy
1,086
I made a plug for one. M16 bolt 1.5 thread I think. Drilled a hole for the fuel can still return threw it. Just screws right into the back of the fprv as the banjo bolt did.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
Found a boost leak, drivers side intercooler boot, it wasn't ripped but it was thin and you could see right through it in a small spot, we trimmed it because it was on the edge of the boot. It runs 100% better but it keeps blowing the boot off so I gotta get another one, hoping James has one if not I'll have to order one but I'm hoping this is the fix!!!!:happy2:
13,752
822
You really don't need to drill the hole. The fuel can flow around the bolt.
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Not going to bother with the FPRV it isn't blowing open, my rail pressure is ok. After we semi fixed the boost leak it feels so much better now, hopefully once I get a new boot it won't blow off and I can get a good run and say for sure.
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
Did yours smoke a lot with the boost leak? or less?
I would think with less boost, it would smoke more?
Having similar issues right now..
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
YAY:woott:congrats man! finally
Noreaster
2,910
Cape Cod,MA
top or bottom boot?
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Put the PPE boot on last night, it felt alot better again, but as I drove it seemed to start getting noisey again and feels like its loosing power especially when I roll into it, the log shows mm3 being limited until a point then it picks up and goes??? Boost on the log looks low too? When we tested it for leaks the only leak we found was the drivers side lower boot, guess we have to retest?
  • 24 zip.zip
