So last night while some people played their favorite gaming system, i installed a diesel race parts fuel tank sump, the no tank drop style. What a piece of cake. Here are a coiple pics
In the above pic after finding the center of the tank, and drilling the 2 3/4" hole using a hole saw, i drilled out one hole ising the sump as a guide hole. Then i screwed in two drywall screws opposite sides of the sump from one another. I left the bit in the hole while i set the screws, cuz it helps to secure the sump while setting the screws, the screws make sure there is no movement while i drill the rest of the holes
In this pic you can see the sending unit. If you drill about 3 or even 4 inches rearward of center of tank you will miss this. See it in there, don't go lettin the bit run wild into the tank, barely let it cut through. Same goes for the hole saw, infact you may want to consider removing the pilot bit to finish the "main" hole. Gentle is key.
The pic above shows the finished product, it is a simple task, it will be nice to go another 75 to 100+ miles before i fill up each time.
