Some more LLY issues
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Can the stock LLY pump & regulator even make 26k?
Also,
This was an email exchange between Kennedy and I
colin stephens <[email protected]>
Mar 15
to John
Okay. So can the stock CP3 on the LLY only make up to 23kpsi? I know the LBZ's number is 26kpsi?
Is there any chance that your lift pump could produce too much pressure? I read a post by Kory Willis where he stated its important to check this.
John Kennedy <[email protected]>
Mar 15
to me
Lift supply only causes issues at above about 12 psi.
The LLY system is programed and designed to run at 23k max. It can go higher, but I would advise against it unless racing.
John Kennedy
Kennedy Sales and Service
W3567 26 Rd
Loyal WI 54446
Ph. 715-255-9433
Fax 715-255-9499
[email protected]
www.kennedydiesel.com
CaptPhil
1,012
Delaware
Yes, just have to command it in the tune. Stock tunes only command 23k.
Another question...
In this DuramaxTuner video on the P0087 code, they mention you can command max rail pressure at idle with a scan tool to bring it to 23kpsi this will help determine the life of the CP3.
I though the engine had to be under heavy load to actually make this test worth while?
https://www.youtube.com/watch?v=KGkuU0A8ntE
It is a better test to datalog under load, but an idle test can show major problems that are present.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Okay, so underload, what should I be paying most attention to aside from desired/actual rail pressure
Burn Down
Sep 14, 2008
7,092
Boise Idaho
The LLY can make 26K no problem, I have had mine there for several years now. The rail test in efi will only go to 23k IIRC. You can do a quick fuel system health ck at idle by maxing out the rail, as others have mentioned. If it won't hold 23k at idle, it's never going to hold under load. Bottle test the rail relief first, then Injector return rate test, if they hold then the CP3 is weak... I'm guessing your fuel system is at 226K with the rest of the engine? Remember the fuel system is a wear item, there not going to last forever...
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Oh really? So when I log in EFI lives scan tool, it wont display over 23kpsi for the actual rail?
Ive commanded max rail pressure before at idle with a scan tool, it held fine. Ive considered between sending my injectors off to be tested vs just buying a modified CP3 at some point, eventually upgrading CP3 anyway.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
No, the log will show up to 29ish IIRC... The command tool will only go to 23. It's been awhile since I was going through all this on my truck.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
Ohhhh I gotcha.
Yeah the scan tool I used to command it would only go up to 23kpsi as well.
Either way sounds like I'm going to need a new CP3 or have my injectors cleaned and tested.
I've been searching trying to find if its something cheap like a ported fuel fail fitting lol, but thats just me in denial.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I might be full of sh*t bud. I'm researching Mcrats rail sensor thread now;) I will get back to you...
At any rate if it's holding fine at idle I doubt it's injectors. I would still perform the return rate test on them.
Have you done the bottle test lately?
I can't find what I was looking for... Someone will correct me if I'm wrong.
cstephens93
Oct 13, 2014
677
31
Tallahassee, FL
I haven't bottle tested in a while. When I did last, no issue. Honestly I don't even know if it's a big deal that I don't make 26kpsi on the max effort tune
