so i finally dynod.....
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
Dyno jet? I was told they were no good for our trucks???, I dyno'd 460 and 851 in NOv on a Dynojet I was very dissapointed, I have twin lift pumps, and everything seems to be right on. Another guy, same year truck with no LP and a PPE hot +2 puts down 470 and 925????? I am going to try a Mustang (load cell) dyno!
slowlmm
Mar 2, 2008
2,582
46
so cal
Drop your pulsewidth. I went past 500 a bunch of times with a 2850 shot. Pressure is your freind.;)[/QUOTE
x2 2850 and 28 psi boost netted me
503 and 1080 the more boost netted lower hp and higher tq on my truck with stock charger.3000us and 28 psi netted me 530 and 1080
624
no two truck are the same.
even more so when compareing LB7 to LLY, LBZ, LMM
X2 pressure is my friend..
all in all its not a bad starting point... really
given the tune really hasnt been changed since i put the new engine in. given the fact that the piston and bowls, compression and cam(06 lbz which is debatable weather it is different between that and a LB7 :rolleyes: ), compression ratio have all been changed to one extent or another
finally got my mpg today as well 410 to 26 gallons weighing 9,200lb ( 2,000# of sand in the back)= 15.7 mpg with alot of idle time and winter grade fuel.. this include the dyno pulls as well
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
what pressure are you guys running i've never tried over 25000-26000 psi how high can you go safely ? current tune is around 3100 usec @ 25000 psi holds about 21k-22k rail pressure through the 1/4 .
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
DynoJet 248C, SuperFlow, Mustang same truck same tune all over 500rwhp
Get you pressure up you will like what you see. I did 507 on Dynojet with winter fuel. Stingpuller, Fingers, Minisub where there. On LB7s I never really had to change the fueling to get the power. The timing is what varied. But what do I know. :cool2:
Keeping the pressure over 21000 was the key for me.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I wouldnt worry about it, duramax's are wierd on the dyno.
With the stock original engine and BD turbo, my 7680lb truck trapped 107mph easy in the 1/4 mile. I think it dyno'd like 450-460 or something silly like that.
