So guess what I broke today?
Big Willy
diesel amateur
May 6, 2009
While tapping my intake today, I pulled off the part that connects to the EGR as well so I could clean it. When I was tightening the nuts to reconnect it, I apparently tightened too much and cracked the cast aluminum :mad:
Anyone know what these piece is called and where I can get another? I hope it isn't too hard to replace :cry:
The part circled in red is where it cracked..the blue is what I need to replace
Anybody know?
13,701
756
It is part of the intake manifold. The part number is 97363568.
13,701
756
It just slips out. Get all the wires and stuff out of the way of it, then pull the pipe to the rear of the engine to pop the bottom out and then the bottom should pop out really easily. You may have to wiggle it a little to get it loose.
jckleewein
Dec 13, 2008
422
Broomfield, Colorado
Pretty much what Josh stated. I also had to remove the black metal coolant hose to get mine out.
Big Willy
diesel amateur
May 6, 2009
Really, it isn't bolted to the bottom or anything? You make it sound easy..
So I would take everything off that I did today then wiggle it lose and get the new one in there?
Big Willy
diesel amateur
May 6, 2009
Thanks for the part number Josh and advice on how to put it on, you too jckeelwein.
This makes me wonder, what should I torque the bolts to next time :eek:
edit: should I get new gaskets too, or can I reuse the old ones?
Big Willy
diesel amateur
May 6, 2009
Thanks a bunch Henry :D
Is it harder to put in or take out? And does 117 sound like a fair price for a new one? Not including shipping..
ripmf666
15,123
14
47
Wentzville Mo
If you have the piece you broke off you could tig it back on.I cracked mine and used a nut and bolt with a washer, We have since cut that part off and deleted the gride heater and the egr and my new pipe clamps to that part you broke off.
