Hmm I would have thought he would have got you thinking that you dont need a lift pump in the first place. Mike is saying the same as me, as long as you dont have a fuel vaccum right at the cp3 inlet then you HAVE FUEL. 17 psi is no better than 1 psi.
Ha, Killerbee did tell me that I needed a lift pump at the beginning of his first tuning. On the 2nd different tune he said it did not need one and it was draining the rail pressure. I knew he was whacked so I added in one and it solved the problem. He still cant figure out why the rail pressure is draining without a lift pump, it drains like a mofo when you hit WOT down to 3k bad. Strange thing was it never popped a low rail pressure code without a lift pump.
I'm not going to get another tune from him, gunna get a better tuning from a well known tuner or probably learn how to do it myself. Either way will work if someone can have the patience of teaching me how to do it.
