Snow Performance= Bent Rod
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Heard of this being done before. buddy had a Labonte kit on his 7.3, parked downhill one night and the water/meth leaked into intake and went to start the truck and bent a few rods. Not surprising to be honest. Snow will tell you to kick rocks, I wouldn't even bother. Sorry to hear..:eek:
9,905
151
B.C.
Only way I can see it happening is if a solenoid got stuck open somehow. It can happen I suppose. Never had any issues with my Labonte kit I used to run.
Ne-max
I like turtles
Nov 15, 2011
3,361
64
Lincoln, Ne
Welcome to the performance world. Parts fail. Get over it. I have many buddies running snows kit with 0 issues.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
The directions clearly state that the reservoir needs to be below the nozzles to keep this from happening. Clearly you did not follow the instructions during the install and now you have to pay the consequences. Fluid will not flow uphill. http://youtu.be/ZeOUfzZbEqc
Jakemax04
Jun 28, 2013
127
Mine leaked down so much the starter couldn't turn the engine over. Mine was an earlier kit without a solenoid for the smaller nozzle. I bought a solenoid for it.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Buda6.7.. did you read this and make Snow Performance aware of your postings ..?
Terms
Warranty Disclaimer
This site and the materials and products on this site are provided "as is" and without warranties of any kind, whether express or implied. To the fullest extent permissible pursuant to applicable law, Snow Performance disclaims all warranties, express or implied, including, but not limited to, implied warranties of merchantability and fitness for a particular purpose and non-infringement. Snow Performance does not represent or warrant that the functions contained in the site will be uninterrupted or error-free, that the defects will be corrected, or that this site or the server that makes the site available are free of viruses or other harmful components. Snow Performance does not make any warrantees or representations regarding the use of the materials in this site in terms of their correctness, accuracy, adequacy, usefulness, timeliness, reliability or otherwise. Some states do not permit limitations or exclusions on warranties, so the above limitations may not apply to you.
Limitation of Liability
Snow Performance shall not be liable for any special or consequential damages that result from the use of, or the inability to use, the materials on this site or the performance of the products, even if Snow Performance has been advised of the possibility of such damages. Applicable law may not allow the limitation of exclusion of liability or incidental or consequential damages, so the above limitation or exclusion may not apply to you.
Mikey
Drag Racer
Jun 13, 2009
560
My snow controller malfunctioned and the solenoid was left wide open. That's why I'm going fuel only.
Ok maybe some nitrous too
9,905
151
B.C.
Tough to mount the tank they give you so it's not above the nozzles. All the ones I saw mount in the box. An under box tank would work if someone had one-which may be available now. Wasn't when I ran water/meth.
