smokes at idle
tomc983
tomc983
Jan 20, 2009
154
New Jersey
i have a 03 lb7 that i cant seem toggure out why it smoke so much at a idel took it to the dealer they had no clue said it was normal but now it seems that it has gradually started to smoke more an more its like a realy light blue almost white smoke any ideas
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
pop the hood and check your coolant overfill tank. does it look rusty???
squeeze the upper radiator hose. is it soft or very firm?
rusty coolant, white/blue smoke, and a hard radiator hose are all signs for a blown headgasket.
maybe blow-by oil too!?
tomc983
tomc983
Jan 20, 2009
154
New Jersey
coolent looks good hoses seem normal checked oil its full had a frind run a scanner to see if theres any codes but there isnt. now this is his thought but he thinks seein the smoke and the fact that it started after i installed my intake but have no programer that it is makin too much boost at idel and not burning it. it dose smell like fuel but its not black smoke
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
Installed an intake? Maybe its an oiled type and fouled up the MAF sensor? You could try cleaning the MAF sensor with electrical contact cleaner.
My next guess would be an injector.
My truck smokes when its cold, but once it warms up it doesn't. Also, it will only smoke if ambient temps are below 10°C.
S Phinney
4,008
Quncy, Fl
I've been told by a GM Tech that GM doesn't really know why. That's why they won't replace them because of smoking issues.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Checking the coolant tank isnt always the best....Taking the cap off is better as you can have pressure in the system causing a false level
coolant
fuel
bad turbo dirty maf boost leak
keep a good eye on your oil check for fuel in it
Good luck
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
You probably have a mechanically leaking injector or injectors. You can check this by removing all your glow plugs, disabling the FICM and glow plug module and watching for fuel to spray out of any of the glow plug holes (protect eyes here) or use 2 strips of card board while cranking the engine over (engine should not start). Sometimes if the leak is bad enough you can just let it idle till the smoke is really cookin then when you pull the glow plugs the worst cylinders will have wet glow plug tips. this is just another test.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Friend of mine has an lb7 that smokes a little. Not much at idle, but hazes when driving. This truck has new injectors. My 03 used to do it as well.
tomc983
tomc983
Jan 20, 2009
154
New Jersey
brought the truck to the dealer on saterday they think my intake is causing the smoke, because it is geting more air and inturn tellin the pcm to push more fuel. anyone ever heard of that?
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
Your dealer is stupid. My truck has a huge intake and turbo on it and it doesn't smoke any. Can you check balance rates? I would be willing to bet its your injectors causing the smoke. This is going to sound crazy, but buy some cheap 2-stroke oil and dump about 1qt into a half full tank of fuel. Allow some time to mix, and check the amount of smoke...it should go down..if its just dirty injects.
