A couple nights ago I was trying to build boost with my pulling truck in the driveway. I was power braking and launching, etc... At one point I hit the throttle and the engine rev'd, but the truck barely moved. The "D" on the shift indicator was flashing. This happened in wet grass on a hill. I shut it off for a few minutes and started it and it seemed to be fine. The only code I had was a TCM P0880, which from what I can find means the TCM lost power. I cleared this code. The code could have been from some time ago, not sure. So I thought all was good. I hooked to the sled yesterday and when I took off, the RPM's went up and the truck was barely moving. I logged the trans in the pits and attached the logs here. I could easily drive it on the trailer. It's only when you really start pushing on the throttle does it them rev with no go.
Truck eng/trans is stock with EFILive tune. Have 30+ hooks on it this year with basically the same tune and have not had any problems.
Truck shows no codes. No check engine light, fluid is bright red and doesn't smell burnt.
NSBU?
Any help would be great.
Thanks guys.
NSBU?
Thanks guys.
