I can only launch at 2-4 psi w t bars down on the 37's gets a little crazy w cognito rods take a ratchet strap around tie rod and go to the front hole by the tow hooks make just tight enough to keep pressure it makes a world of diff
take a strap run around your tie rod and pull toward the front of your truck to your tow hooks you will be able to launch harder because its keepn foward pressure on your rods before i was only able to leave at 4psi tops
