more pics
Pics 1,2,3,4 in the first post are of the rear DS. I drilled through the rear housing on the fins on eash side and twisted the flat steel to give it strength. I leave these on year round (as you can probably tell). I believe the rear shields were 8" dia. pipe and the fronts were 6" ( but you will have to measure your ujoints to make sure and leave yourself and inch on each side is what I did. The loops were made out of 5/8" round stock that I just had laying around. Just heated in vise and bent slowly. These were welded to the frame and stay on year round. Make sure your bends allow your front ujoint to come through the loops for removal of the shaft for repair. The front of the rear shaft I made a crossmember out of angle iron and gusseted up the shield as you can see ( if you need more close up pics let me know). This crossmember also make a good place to mount your aftermarket fuel pump.
Pics 5 from the 1st post and the rest from the second are of the front driveshaft. These are kinda a PITA. I made a crossmember that goes from the transfer case crossmember to the front axle support. This will hold the loop (mine is gone because it ws rubbing because my motor mounts ripped - have since bolted new ones but have not replaced the loop yet). Make sure the loop is big enough to let the shaft slide through for maintenance. I used the same 5/8" round stock and welded it to the crossmember I made. There is a notch in the tranny pan that you can mount the loop next to that works well. The shields were fabbed with a support to raise the rear one up and hold it in place. This support is bolted to the transfercase crosmember for easy removal. The front shield was mounted to the big bolt on the reand housing support and the stabilizer bar on the lift kit. This allows easy removal and all these are left on year round.
MAKE SURE you have good (bolted) motor mounts and good tranny mount before installing this. You WILL have sparks at your first pull if you don't.
Let me know if you need more pics. Hope this helps someone!
