Single Phase or 3phase power Info please
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Wow ... Do you really need 60HP for a well???? That's a huge fricken motor.
I would find out more info why that much HP is needed. Even 3ph is going to eat you alive in electric costs. 50kWh * .20/kWh is $10 per hour that it is running.
$240 a day for continuous use?
I thought the same but was scared to say anything as I wasn't sure of the application completely! 60 HP is HUGE
dmax711
Mar 4, 2011
1,057
concord, north carolina
To give you a better idea a 3.0 L 50h.p. generator running on propane or n. Gas puts out about 250 amps. Now depending on load lets say 1/2 of what the generator is capable of it will consume about 1.9 gallons an hour. 3/4 load would be 2.9 gallons and full load would be 3.3 gallons an hour. Depending on fuel cost in your area you should be able to crunch some numbers and get a pretty accurate idea of how much it will cost you to run it monthly.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
200 hours runtime:
You need a watertank, not a big pump.
You could make do with a much smaller motor with a big tank.
You need to consult with an irrigation specialist.
bobxr50
Been around
Mar 3, 2008
61
mn
Just a information note:
You can use a variable-frequency drive (VFD) to transfer single phase to three phase.
You have to double the size of the drive to do it though.
20hp motor you need a 40HP drive.
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,187
Edgerton, Ohio
The problem is building a water tower of sufficient size in the middle of my field is not economical or practical either. It would have to hold 4,000,000 gal and evaporation would kill me in a pond. LOL
I thought about the combustion engine water pump, but most pumps won't suck up 150'+ and to prime it would be a bear to say the least.
The consultant says to pay the money for 3 phase, VFD, and let the well driller tell me how big my motor has to be for 800+ gallon per minute and buy accordingly. I just wanted to make sure things were as efficient as they could be as far as costs and ROI since I know nothing about electricity, I feel like I am at their mercy.
Local electric coop will run me a single line 480 for free... FWIW. Yet 3 phase is $18k.
The price of this stuff is crazy! :eek:
Just thought I would throw this out there since a lot of you are a lot smarter than me.
Any VFD's higher quality or better than another? I did read on line that there are some known bearing issues when running VFD drives something about they arc across to the shaft and wear out/pit the bearing prematurely. I am young and I just don't want problems, regret, or have to redo things.
matt78
Finally boosted launches
Sep 10, 2012
924
texas
Well my statement on a vfd converting single phase to 3 phase was wrong, however there will be issues doing that setup, man I wouldn't do it unless it was a little 10 horsepower well pump. As far as bearing issues they make grounding rings for the motors and danfoss sells blue cores, which you run the wires going to the motors through the blue core to eliminate etching the bearing race. I only work on 3 phase equipment so I was not aware of the single to three phase vfd stuff. Danfoss also makes vfd's
Fingers
Village Idiot
1,717
96
White Oak, PA
There are single to 3 phase VFDs. I run several. They do not change the voltage, they change the frequency, which in turn changes the motor RPM. Thus the Variable Frequency Drive name.
Something to run 60 HP will not be cheap, but probably cheaper than $18K
I use Baldor VFDs a lot and think they are one of the best. I have never had to, nor heard of anyone having to repair one.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
When you start looking at prices like that, you should also consider 3-ph solar.
Why? 30% tax credit on not only the solar, but on the distribution lines to the utility.
The solar doesn't have to be 50kw. The utility will have to "save" your power when the pumps aren't running. Think of the utility as a water tank, or a big battery.
OK, is this a single field flooding? How is this water used? Times per year, duration of flow?
matt78
Sep 10, 2012
924
texas
Fwiw, the grounding ring has brushes that touch the shaft of the motor, you epoxy the ring to the endbell. Only thing is the brushes will have to be replaced from time to time. The danfoss blue cores would be better.
$chultz38
230
5
I work for a rural water company. We have over 30 cutler hammer vfds with no problems. Converting single into 3 phase is easily to do with a vfd and works well. Even if you run 3 phase I would use a vfd to start and stop the pump to prevent water hammer into your system. Have you priced a starter yet for the 60 hp motor yet? Like others said you can program the drive to run off of outlet flow and pressure. Are you sure that you can withdraw 800 gpm? When using a vfd make sure the motor is inverter duty rated if you want it to last long.
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,187
Edgerton, Ohio
This will be a center pivot traveling irrigation on rolling sandy ground. I have the river on the back side of my property but I do not own to it therefore I can't source it.
Yes, I promise the 800gpm is accurate. When they are close to the road they put a fire hydrant hookup there, and the FD loves it! :D Then they have a master key to get into turn on the power on and they are trained on how it works.
matt78
Sep 10, 2012
924
texas
If you decide to purchase 3 phase power you can get a bypass contactor for your vfd, so if the anything in the drive fails and you are in a pinch you can still run a pump. However it might not be that critical for your situation.
hdd-max
Apr 30, 2008
56
I don't think 18k is that bad. You just need to see how long it will take to get that investment back. Do all the numbers on the complete irrigation system and expected average yields. If it's going to take more than 5 years or so to pay back then I would not do any of it. IMHO
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
You might talk with your accountant (not a salesman) about a small 3ph solar system.
Why? Free money. If your $18,000 utility install is part of a solar install, everything you do is subject to credits and grants. Federal credit is 30%. I think Ohio even has up to a $25k grant for grid tie arrays.
You might get both utility 3ph and solar 3ph for less than $18,000. AND your 3ph conversion might qualify for credits and grants under Ohio energy efficiency programs.
But don't talk to solar salesman. They are normally greedy and clueless.
Fingers
Village Idiot
1,717
96
White Oak, PA
Solar could make use of those pesky unirrigated corners of the field that the pivot system doesn't reach.
However, my experience is that in our climates here in Ohio and Pennsylvania, Solar barely pays back in 5-10 years. That's WITH the incentives. Then there is the hassle factor.
Finally, Solar is not maintenance free. MTBF on affordable panels and batteries is somewhere around 20 years, but getting better.
Farmers have better (more profitable) things to do.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I'm not going to say it's a fact, but from my reading, he may be eligible for a GRANT from Ohio. This might cost his little or nothing to get utility 3ph installed to his property IF it's part of any sized grid-tied solar system. An accountant would know more.
So you're not installing solar as a long term investment, you're installing it to reduce the cost of getting 3ph to the property. But since he's only using 200 hours a year, even a small array will help pay for his juice to run the pump. And if a 3ph conversion qualifies, he can get a grant for the pump motor and controller as well.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Example: Put in a $4000 3ph grid-tie solar array that requires an $18,000 3ph power run. Cost = $22,000, discount = $6,600 Federal. $15,400 for the utility power. This is assuming there are no Ohio programs, which is false.
If this is the case, the solar nets a nice profit first year. Take the profit and expand until electricity costs are completely gone for the whole farm.
