Simon's new test mule
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Went to the lame course today on how to use a fire extuingusher
Anyway the wire haness is swapped,problom is I have 01 sensor and 01 harness BUT no oiil press sensor harness that plug into the sensor
9,906
152
Went to mthe lame course today on how to use a fie extuingusher
Anyway the wire haness is swapped,problom is I have )! sensor and )! harness BUT no oiil press sensor harness
Well, you were wondering what gauge to put in that last empty hole. Maybe ditch the stocker and go Autometer.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Sorry for the late responce:eek: I'll have to look. Is that the plug on the lower drivers side of the engine up close to the front? Got a pic?
Ill get a pic of the 03 sensor,I had to go away to work so it wont be for a couple days
yes its DS close to the front
9,906
152
How the hell are you working? Isn't it pouring rain and flooding everywhere there?
9,906
152
Yes I am lucky to be working in the pouring rain:rolleyes:
Equipement is on and only took 36 wheels under it to get it on and 2 D8 cats
I love the mud
Same here. Took 12hrs to move 8 trucks 2 miles yesterday with 2 K700 rubber tired loaders and a D9N. 90 000lbs + sandy wet roads = Gay!
It also took the water haulers 4 days to spot 8 - 330 Barrel tanks and fill them! Just to do a 130 ton frac that took a little over an hour and a half to pump!!
I'm trying to get video from somebody here but not sure if it will work.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Call me if you need some harness stuff. I have a complete 02 engine/tcm harness.
Thanks for sending it Joey:hug:
I ordered some slicks yesterday and the new turbo will be on at the end of the month.....Im taking next monday off to finish the truck and fire it up
wheel alingment and break er in.......then let the fun begin:D
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Its alive!
but not well,we had it running for 10second spurts 3 times and everytime it leaks fuel? all the connections where tightened to spec 37ft/lbs first was the obslolete
pop valve that is now a plug then the connection to the rail from the second cp3 then the first cp3, but we cant see the leak its somewhere around the factory cp3 but all you see is a mist and it wont start now
Im ready to chuck Teds computer out the window.......cant get it to select fuel pids or pressure WTFF they are not even there and ofcouse my laptop is dead:rolleyes:
anyways we knew there would be issues and other than the fuel leaks it sounds awsome and mean:D
the cp3s are not maxxed out but rail pressure must be pretty high as we keep getting these leaks?????
anyways i got get back to the town im working in so I had to leave
we will keep on keepin on on monday
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Woo Hoo on the starting :hug: I hope you find the leak :(
Thanks Kat but what concerns me most is WHY? the fuel pressure doesnt sound high?Sure would be nice to know what it was though
I know first hand the sound of a maxxed out cp3 and this aint it,but why all the leaks? the duel fuel HP line is brand new and so is the fitting? and tq with a crows foot to GM PPE spec Ive had probloms before over tightening the lines and dont go there any more:rolleyes::)
well a fresh day and we might get it going,today was a late start and a complete rush into things,Perhaps monday will prove to be better
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
surely ts something easy, fresh eyes on monday and I bet you get it figured out ;)
ya larry i mean things could be worse...right? it does sound good when its running no knocking or anything but if the stuff leaks now whats going to happen when it gets some real pressure?
I think idle is only what 30- 60 mpa max right? what happens at 190mpa:eek:
it seems to go in a downstream motion too first the relief valve then the lines into the rail but the cp3 doesnt seem to be coming out of the HP line and more like the body:eek::eek::eek:
