sick of this crap
sparepartsracing
spareparts offroad&fab
Mar 17, 2010
773
well first off idk how my tranny is still together. I run either the stealth 215 tune, or the ppe hot tune on any level:)roflmao:), now i have 20"s and 33x13.50 nitto terra grapplers....now usually when i have my transfer tank(custom made 120gal rectangle that lays over the wheels)..and i keep it 1/2-full tank... my truck will keep traction and take off like a bullet(not as fast as you guys but fast to me:woott:) but i sence took all that out sence i bought a littler chevy to put that in so this isnt my work truck anymore, now on my stealth 215 tune i can bake the tire completley dry pavement until 4th gear(tranny should be blown by now):rofl:...i usually launch in 2wd but i raced my dads friends 2011 camaro ss last night(what a big hype for a shitbox) anywho...basically what im asking is what type of traction bar do i need...i tow a two car hauler with two full sized offroad truck or race cars, does that come into play?
sparepartsracing
Mar 17, 2010
773
well that, and the traction, just not sure what traction bar to go with....what are the pro's/con's or does it not matter
Oct 16, 2008
948
12
Idaho
Seems a lot of guys have had good luck with caltracs. Plenty of info on here about them. A search will probably net you everything you're looking for and more. :)
sparepartsracing
Mar 17, 2010
773
yeah ive been searching sorry should have been more accurate with what i want to know.....does it matter if you tow a trailer with them or is their no difference i have a traction bar setup on another truck but i cant compare it to to this...
5,818
traction bars wont fix this issue. they stop wheel hop/axle wrap upon launch. if your breakin the tires loose that bad, the bars wont help you much
sparepartsracing
Mar 17, 2010
773
what should i do sir....kinda lost on this situation but its kind of getting annoying to me....everyone thinks its a cool factor around here but its boring
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
I don't tow a lot, or real heavy, but I have never noticed an issue. Long bars should cause less issues with suspension travel (heavy load bringing the back down for example)
5,818
get yourself some different tires (proxys seem to be the fav), use 4wd, use throttle control. i basically have no 1st or 2nd gear from a start in 2wd with a no boost launch. i have to use 4wd or give it jsut enough juice i dont rip the tires off from a start, then hit it hard once im almost through 2nd
sparepartsracing
Mar 17, 2010
773
yeah not a fan of the street tires...alright ill just have to deal with it i suppose:rofl:....guess its still fun passing people sideways...thanks guys:hug:
5,818
guess traction bars are pretty worthless on the street:rofl:
they look cool tho!
They actually serve a very good purpose that is usually un-noticed by most (even i for a long time). with the power we make and tq, you get a decent amount of axle wrap at take off or in the lower RPM ranges where TQ is high. this puts added stress on the u-joints of your drive line and will wear them out quick due to the drastic changes in angle and "bounching" of the pinon. Untill i put my bars on, i never knew how much wrap i actually had.
yeah i wouldnt be afraid to click the 4wd in at any speed below 50. ive done it at 75 a few times but i wouldnt recommend it lol
sparepartsracing
Mar 17, 2010
773
ha ha yeah im making of traction bars on my 77 chevy k10 but i did that because of the axle wrap/hop with the 44" tires and the diesel :) didnt think this was as bad as with 33's maybe ill pickup a set
AdaMax
Nov 26, 2010
412
Caldwell , Oh
Also if you put it in 4X4 on any dry pavement or while moving you need to have the same size tires front and back and be sure to let off the throttle while shifting . Front tires with half tread and back tires roasted till they look like slicks are not good to play on dry pavement with . I'm not trying to be a smart a&& .
sparepartsracing
Mar 17, 2010
773
yeah i know the 4wd gig but these trucks arent as strong as the old k10's figured they would go into some king of safety check if put into 4wd while rolling...tires are brandy new :)
