Should I strap my centre link and defuel question?
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Here my pull from last night. Watch the the toe in and defuel at the beginning of the pull. My tbars are all the way down, I have Cognito pitman, idler arm braces and HD tie rods. I don't have the time or money to get a straight centre link before next weekend, would strapping it help? Does anyone know of a good way to do it? Also isn't that defuel crazy, I bet it costs me 10 ft.
[YOUTUBE]Niv2PnJZQGs[/YOUTUBE]
hogdoghd
Adrenalin Junkie
Jun 24, 2008
91
Oxford, Ohio
Wow; with a lift I don't really know how you would strap, are you running stock keys or green keys? if you do not have a straight center link then yes, you need to strap your front end some how with out a doubt! Oh yeah turn your lights off next time, leave just your running lights on;)
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Strapping is always going to help, strap it. Here is a link with some good links and pics. http://www.dieselplace.com/forum/showthread.php?t=162372 I had 05Smoker and his brother show me the first time.
Thanks that should help.
They are stock keys with the bolts out and I can't turn my day time running lights off and the dealer won't because of insurance reasons.
Oct 16, 2008
948
12
Idaho
I strap my centerlink and it seems to help compared to the times I didn't. Get less pigeon toe action and I only have cognito rod ends. The only thing that concerns me is I can tighten the straps all the way before the pull, then after the pull they are so loose I can almost get the strap off without releasing it. :eek:
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
That's interesting, I will strap it for next weekend for sure.
hogdoghd
Adrenalin Junkie
Jun 24, 2008
91
Oxford, Ohio
If you turn just the running lights on, the day time running lights should shut off. ;)I think, at least they do with my truck, or just pull the fuse for the dtrl. Oh yeah I have yet to see a LMM not defuel like a mofo when pulling importkilla's truck defuels so bad it nearly leaves the ground!:spit: Good luck!
13,716
779
You should also be able to turn it back past the off position (spring loaded momentary) and turn off everything.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I bolted some rachets to my truck to strap my centre link like Tomac's. My truck is lifted 4" in the front, not sure if that matters but do I crank the straps as tight as possible? Will it turn at all with them totally cranked? Sorry just a little nervous going pulling tonight. Oh and thanks I'll try and turn the daytime running lights off.
Oct 16, 2008
948
12
Idaho
I crank mine about as hard as they'll go. I just make sure not to turn too sharply. The bar seems to slide in the strap while turning but I use reverse to turn, ALOT. :)
ruffmanatv
Yeah, its got a D-Max!
May 9, 2008
3,640
46
Van Wert, OH
Yeah I make like twelve point turns. :D
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
Good luck let us know how you do and defiantly post some vid's:D
Truck ran like a raped ape untill the P0087 code popped up, got 2nd still. Vids will come later
Thanks I cranked mine as hard as I could also I think it really helped.
LOL I know exactly what your talking about.
