Hey guys.
My wife's 03' LB7 was getting random Shift range inhibited messages. Truck had an ATS built trans in it when we bought it.
It would also shift very hard from 1st to 2nd. and every once in a while when you shifted from reverse to drive it will thorw a shift range inhibited message.
First thing I did was change out the NSBU switch. That seems to have cured the hard shifting from 1st to second. But it would still throw a random inhibited message.
So then I decided to put a new ignition module in. I tried to match up the teeth as well as I could on the little gear of the old one. I thought all was well after a test drive. But now it seems like something is out of sync with the gear selector. Sometimes when you go fro Reverse to Drive, it acts like it is still in Neutral and you have to click it down one more gear. other times it works fine in drive. Truck still drives and shifts fine. any suggestions??? did I install the ignition module wrong? also the gear indicator backlight is very dim, in the daylight you cannot see what gear you selected. any fix for this?
Thanks for the help
Thanks for the help
