LB7: Shifter is sloppy and falls out of gear(park)
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
My shifter won't stay in park any more. The trans is in park but the shifter falls out and creates some problems when trying to start the truck. The trans is brand new and I'm not getting any shift range inhibited messages. New NSBU switch too.
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
The slop is in the shifter not the trans. I checked the trans (new) when installing it. Used vice grips with a ray over shift lever it was very firm. The column shifter wiggles all over the place back and forth three to four inches and up and down one to two inches? I searched a lot of sites and this doesn't seem to be a common problem with these trucks.
Dallas S
486
33
Alberta
There's a spring in the coloum at the base of the shifter that keeps the shifter pushed back(towards dash). I've replaced a couple now cause they have broken. This will cause the tumbler to stay locked ect
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
Pulled it apart tonight, pretty sure that's it^. There's a little lot metal switch in there too, mines broken. Going back together tomorrow.
dirty_max
815
eureka il
let us know how much of a pain it is, i have to do it to mine, and hook my tow haul wire back up. for some reason it is unhooked and hanging out of the boot
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
I got the parts from the dealer. I'm now fighting gear selection issues. Goes in reverse when selector is in neutral, also hard to get into park. More adjusting is needed.
15,681
Disconnect cable from trans and set trans lever in park. Then put the shift lever in park and pull the key out. Make sure wheels are blocked. Now release the cable adjuster with a screw driver ( it is a 2 piece cable). It is next to the frame on driver side. With cable released, connect cable to trans and then lock the relase. You are done.:D
