Shackles
wikdlmm
<-- OWFA
Jun 27, 2008
1,974
san angelo
I am going to be putting lowering shakles on my truck. Is there any other modifications I need to to? Any bed mods? Do I have to take out the overload?
Diesel Pilot
Hat? Suitcase? 50 BMG?
Aug 9, 2006
1,424
47
Pickerington, OH
By putting on drop shackles, the pinion is tilted forward by a few more degrees. In some instances too much pinion angle can cause problems with traction, drive shaft bind, proper lubrication of the rear end, ect...
I don't think there is really anything you can do to the front hangers sort of torching them off and welding them back on in a new spot. The other option is to cut the spring perches off and weld them back on at the stock angle.
The third and most popular options is to put the drop shackles on and enjoy the new stance of your truck without anything else done. Many, many people run drop shackles alone on these trucks without any issue at all. You can just put them on and be done with it. To get a few more inches lower, you could take out the overload.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Well said. Thanks
Depending on how low you want to go.
Also, talk with a shock dealer and get the low down there.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
you can choose to remove the overloads, I did and gained another 3/4" drop. you gotta pull the oem hitch, but that doesnt tak etoo long.
duramaxxx06
Aug 11, 2009
177
jasper tn
how much of a drop you going with the shackles? ive got a 3 inch on my gas truck. been on there for 78000 miles and no issues yet. . knock on wood. .
Fat_Robi
I may be wrong, but...
Sep 7, 2008
232
Las Vegas, NV / Provo,UT
Y do I have to remove the hitch?
Because it gets in the way of pulling out some of the shackle bolts, or at least that is what I have heard. You could cut them once they are part way out and replace them with shorter ones that you can put in from the outside and will not hit the frame I suppose.
13,716
779
I would recommend you do NOT install a degree shim on something that is frequently driven on the street or at high speeds.
