Service stabiltrac and park assist off
Jan 30, 2011
59
Sacramento ca
So I straight axled the 15 lml and now I got service stable trac but my abs works fine because I made a abs tone ring for the Chevy and did that right but park assist is off and stabil trac so are they seperate system? Doesn't make sense why abs works but that quit working
ikeG
Oughta Know Better
Apr 19, 2011
2,462
146
Western PA
www.facebook.com
On the older trucks, you could disable park assist by removing the fuse for it and then disconnecting your batteries for 10ish minutes. When you hook power back up it will not recognize park assist and will not enable it, like as if it never was equipped. Not sure about the '15+ though
Jan 30, 2011
59
Sacramento ca
Well I want it to work but I'm just curious if it's a different system then the abs because I figured if abs works like stock that be my only obstacle but abs works but this don't makes no sense
Jan 30, 2011
59
Sacramento ca
So pulled codes and steering wheel position sensor wasn't communicating to scanner so changed that out but still got light. Does imthat sensor have to be calibrated
minerigger
2,660
Casper, WY
I was under the impression when an alignment was done on newer vehicles they have to recalibrate the steering wheel sensor to zero with the steering wheel level after the alignment or it will set lights and codes...but I could've been lied to and be full of smoke now.
