I want to start a "Serious Brake Thread" to talk about all the upgrades, maintenance (preventive/corrective), aftermarket parts, and general knowledge surrounding the brakes on our trucks. We spend hours and hours about how to make the trucks go faster, but we spend very little time talking about how to make them stop safely. I know the stock brakes are pretty good but over time they get bad and they can be made better.
Background into why I want to start this thread:
I've had various problems with my brakes ranging from the pads sticking on the sliders to having to totally replace all brake hardware in one service. This weekend, after what I thought was adequate preventive maintenance, I noticed my pads sticking to the sliders again. This is after grinding and wire wheeling the pads and bracket to get proper clearance at the install about a year ago. I check my pads and sliders every tire rotation and they were fine about 3k miles ago. So I can't blame it on winter weather and salt this time. On this set of rotors and pads, I've also noticed a "warped rotor" effect that I also remedied this weekend by having the rotors turned.
So it seems that every 5-10k miles I will have to pull the brakes apart and re-grind and wire wheel the pads and brackets to make sure everything is loose and moving the way it should or risk a total brake replacement again. I need to get the special brake grease to put on the sliders, this might help a bit.
I'm interested to here what some of you might have done to help this problem and if you don't have the problem what hardware you have installed that might be contributing to prevention.
Here is an interesting article about warped rotors or the the effect that causes them, and also how to prevent it from happening.
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
Also, let's talk about the spongy pedal feel that sometimes comes up in these trucks also what brand and type of pads, rotors, or hardware you guys have had good luck with. I'd like to put together an information thread about combination's and techniques that the DIY'er can do in their garage without breaking the bank.
