LLY: Sensor on intake runner
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
What is this sensor that is on the intake runner.. I'm putting lbz runners on and they don't have a spot for this sensor.. Knowledge please???ImageUploadedByTapatalk1357343361.584047.jpg
SgtKilroy
'Merica!
Sep 30, 2009
859
SoCal
You can add a small hose barb to the hole in the LBZ Y bridge then run a piece of hose from the hose barb to the map sensor. Just zip tie it out of the way. I did that to my LLY when I added LBZ runners and no problems at all. It was RDL's idea and I'm sure he knows what he's doing.
THduramax
Will it ever end!
Aug 15, 2012
407
Flaherty, ky
I assumed a code would show up if i left it off. Ill rig it up somehow on there.. Iv got a pro fab y bridge that has a lly intake throat to lbz bridge and lbz runners.. Everything is alot bigger than what comes on a lly.. Big air
doug9940
Ca LLY
Dec 6, 2009
391
56
Corona, Ca.
Where did ya get something like that???? :thumb:
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
How the hell do you expect his variable vane turbo to even work at all when the ECM has no idea what the actual boost is. :rolleyes:
I don't want to get in the middle of anything but i wondered this as well.Thought if it didn't see x amount of boost it would just limp the truck.But what do i know
