sell my stock navigation head unit
KEVINL
1,431
Phoenix, AZ
I replaced the stock Navigation Dvd head unit with a Kenwood
My question is can I sell the stock navigation head unit and will it work in another truck? also what is it worth?
13,712
772
It will work in another truck, but it will have to be unlocked.
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Not sure if its the same now but back in 05 I tried to put a stock CD player from an 04 into another 04. It would turn on for about 30 seconds then say locked.
GM told me it was locked to the vehicle it came out of and there was no way around it. I brought it into the dealer and they attempted a few flashes but it never took.
jewelaudio
Apr 16, 2012
35
Morris, IL
you should be able to sell it and it should work. They will have to take a trip to the dealer to have the bcm flashed and add a nav antenna.
If you do sell just be up front with who ever buys that it is sold as is and it is there responsibility for the antenna and trip to the dealer. Also be up front that because of the vehicles computer there is always a chance that it will not work. You would be surprised anyway if you throw it on craigs list or something. More than likely you will find someone who has nav and just needs a replacement. Keep in mind that that unit is almost 2k from GM. So if you sell you should get a decent penny for it. Especially if you find someone who needs a replacement and not just trying to upgrade.
RichLMM
699
North Kingstown RI
Where does the antenna go? My truck is an LT also, will the nav unit work in it you think
it should i dont see why it wouldnt? take the 2 pillars off and the front of the dash comes off and theres a spot in the middle of the dash for the antenna...its the same shape as the antenna so its a no brainer....
Trevor
08 LMM
Jul 8, 2010
47
Ontario Canada
Check out gmcnav.com. They can point u to every thing u need. If u don't have Bose you will have to buy an amp. Like I said check them out good info.
