Sell dmax for 1500?
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Ok... So ive been thinking about this for about a month or so. My dmax adventure has led me to nothing more than a good motor and trans. Other than that, it's been a knock down drag out all up hill with things such as fuel pumps, tuning and some dictatorship over this whole dmax performance stuff. Don't get me wrong, I love this community and love the people I've met. But damn.... I'm in the military. I make like $2.00 an hour. So I'm thinking of a more budget friendly toy....
Now comes in the 2003+ chevy silverado 1500 w/5.3L LM7. I've read of numerous people on several forums running these budget motors with single S475's or twin turbos (size on twins I do not recall) with only MOTOR upgrades being head studs, springs and a cam for added power. Springs and studs seem to be the only supporting mod. However, a lot of guys (not all) have chosen to run ARP rod bolts as well. I don't blame them. Still, all around, that's CHEAP!
Kay and pat, hope yall don't object to these questions as this is a dmax board. If so... Erase at will.
My question is towards any guys with LS experience. I've noticed that people run 80#/60# etc. injectors but depending on E85 vs premium, some injectors won't work but others will? Can any of you explain to me what these other guys Are talking about when they say "IDC is xx% @WOT" with said injectors? Its seems like the injectors are just at their point of max fuel and that's as far as the motor will go. They are the weak link. YES I KNOW "Idc" is injector duty cycle... But what's the difference in all this with E85 vs premium?
I'm just trying to get some basics before I venture to them for questions. They are some cut throat ****s over there. I don't wanna deal with their "you never been on a forum!? Read a sticky!" bs
I just don't know much on LS performance. I've built an LM7 from ground up.... But it was stock specs. Idk much about cam durations, head cc's timing, NA vs FI etc.... I know that you add **** tons of fuel and air to a dmax and you go fast. That's about it.
lddrew
shootin for 13's
Jan 10, 2011
216
West Georgia
subscribing. I read the write up about the 26psi of boost through a 4.8 with stock bottom end and decided my dmax might not be the best vehicle to hot rod.
13,711
772
I'm not really sure exactly what you're asking, but the IDC will be higher with E85 than it would be with premium gasoline. You must inject more fuel for the same amount of power with E85 because there is less energy in it than there is regular gasoline. The reason you are able to make more power with it is because it is more resistant to detonation than regular gas allowing you to run more boost and spark advance.
mean06
Feb 27, 2012
21
Ls1truck.com , there will be quite a few people that could help you with any question you may have.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I rode in a extended cab 6.0 down her ein PHX with a S475 and man... made me think twice about a dmax going fast.. ;)
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
IDC will go up approx. 30% with E85.... maybe a little less because you can run your motor leaner due to far lower egt's on E. I've found some injectors for LS1 type applications were a nightmare to tune. Siemens and some deatschwerks have been painful. The spec sheets they sent were not even close to accurate for latency's etc.
Anyway, E85 is great stuff :thumb:
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
I'm pretty much just asking for info on E85 and their injectors. Not sure how their ratings apply to much of anything. 80# injectors... Are those like 80 overs for us? I was a little drunk when I wrote this :) haha so it didn't really get to specific questions. I know about all the forums. Seems like a lot of the noobs get shot down pretty quick though.
Do any of you have experience with modding these trucks??
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
Would you recommend using E85 over higher grade fuel?? I'm guessing IDC goes up just bc the lack of BTU's in E so it just requires more of it?
