Question: Safe tuning basics?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I ran 2900 with 45% over injectors :eek: the stock motor didnt break , well right away anyway :D , most guys run around 3100-3200 on there race tunes , single cp3 with lift pump .
Jasondt2001
May 3, 2008
373
Salinas, Ca
ROFL - I've followed your posts... Your truck is my trucks idol!!:hug:
Im going through a unwanted divorce, and if i wasnt so worried about money and where it's going I'd have a tranny fund back, and some savings for a motor when needed...
Hence the reason I'm being careful....I REALLY dont want to give it up!!! I like the tune!
TrentNell
Jul 7, 2008
7,543
slc tuah
I woudnt be too worried about that tune , i think it is fairly safe for the motor , trans probably not but it will take it for a while .
Jasondt2001
May 3, 2008
373
Salinas, Ca
GREAT!! I have a really light foot, I only get into it when Im goofing off which is not much lately...most of my driving is freeway....
What I WANT to learn is - how to use fuel based torque values rather than the B0720 values in my own tunes.... I change it, and try it, and it gives it a little oomph, but, no where near expected. I just LOVE how the DIC is accurate when i do it that way... :thumb:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I listened to all your guys advice
I changed my timng to 20* and my PW 2000 at 10 mm3 + I maxed my TBIQ to 100 at 400 rpm + ande maxed the TQ tables
SOMETHING IS WRONG?:baby:
Can someone fix it for me?:angel:
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
:eek: good point Simon :rofl:
Wasnt trying to discredit all you guys advice as it is all good!
Just trying to make a point that it doesnt really matter what the max is, It is more where you add the max....I know you guys know this, But others reading may not.;):)
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I have had good luck using the A timing table in place of the C table (ala McRat 20/20 ;)). It is a GM table so I figure it is pretty safe. PW I add a little to as well but don't go crazy. Drive the truck and see how it feels. On my DSP2, I have a good everyday tune that has good power, is smooth, and gets good economy. I rarely switch to the big dog.
On an LB7 this WILL rattle at interstate speeds and a steady cruise. I found more than 6 degrees at 2000+ RPM's steady cruise of about 20-25MM3 of fuel and she rattles, but keep it at 6 and you're fine. I was able to get away with 7 in the summer, but it didn't help my milage any(actaully hurt it some). I really feel like a wimp everytime I read what some of you guys are putting through your trucks. I'm datalogging pulsewidths in the 1900-2000 PW at roughly 158-160 MPA of rail pressure with timing right around 20 and it torques hard enough to twist the left front up pretty hard. Alls I know is my current tune will get from 70 up to about 110 alot quicker than a SUBURBAN should be able to.
Dozerboy
4,926
507
TX of course
I run ~1950mm3 with low 20s for timing for a DDer. Any more and the trans start to slip some. I have some hotter tunes but I like playing around at this level to learn. I can do WOT runs in warmer weather without spinning the tires a lot in 2WD. My truck is to inconstant in 4WD to really tell anything on small changes. I've ran 9*-14* of timing from 20mm3-55mm3 at 1200RPMs with no rattle on a warm engine. Wasn't to bad with it cold(50s) but I was getting some.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I was able to run upwards of 7 on a 80-90 degree day at the 20-25 MM# of fuel range at 2000-2200 without rattle. When I downshifted though or let off the throttle it rattled pretty bad, and below 60 degrees it sounded like it was gonna come apart on me. I noticed that the LLY/LBZ guys seem to addd more timing in there tunes than I can from what I have found in tunes in the tune library at DP. I'm still a newbie to tuning though and have to than TRENTNELL for helping me out.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
My old daily driver, tow tune was 1764 PW, max of about 24* timing, and 182 mPa. It ran 11.5 @ 119.:D Gotta love the 100% injectors. Since running it at the track I have written a few weaker tunes and normally run around on a tune with 1534 PW that would probably still run high 11s.
