LB7: Safe lb7 egts?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
A lot of times the bigger chargers don't reduce EGTs as advertised either from what I have seen and heard on here.
Especially when you add more fuel to compensate for the new found air.:woott:
My big charger only helped egts at idle. Best thing to do with an egt gauge is unplug it unless you tow really heavy through the mountains and you lack common sense.
DMAXDOC
May 26, 2011
119
My water/meth dropped mine at least 250 degrees, wonder why such different results??
JustinD
Plow Truck
Nov 21, 2008
2,067
42
Tiverton Rhode Island
When I ran water/meth 50/50 mix it wouldn't drop egt's much but it felt a little faster made 26 rwhp on a Mustang 2000 dyno too, just straight water worked good about 150*-200* cooler
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
compounds help the EGT's but increase the temperature of both the oil and the air temps going into the intake. mainly because it has to force the air through your small chager.
PS on a WOT with a max effort tune & twins, the EGT's can still bury a 1600 degree guage.
THE COMPOUNDS DID HELP WITH EGT's tho. with my stock IHI i would bury the 1600 guage by the 1/8th mile, with the twins I almost hit 1600 (1550ish) by the end of the 1320
DMAXDOC
May 26, 2011
119
Man I run 50/50 usually, sometimes more meth, but I feel like its way more power (seat of pants) when the big jet sprays ( 12psi) comes on like a freight train.
I would have bet on an easy 75rwhp gain until you said that!!!
JustinD
Plow Truck
Nov 21, 2008
2,067
42
It did feel awesome, and thought it would add more too, but it didn't. Also striaght water makes the same power as no water, I know alot of guys who tow and they said it felt like it took power away, its the same.
bean
Feb 5, 2011
66
Norwalk
Is the a difference from lbz to lb7 egts? On my race tune I Hit 1500-1600 but only for short bursts, just curious
