This thread will be a long-term review of the SAC-style +75% injectors I put in my truck, and how they hold up.
Backstory
As described in my [THREAD=70438]other thread[/THREAD], I had a set of +100% injectors take a giant crap 9,351 miles after Exergy had given them a clean bill of health.
[YOUTUBE]cKWdxVv66tI[/YOUTUBE]
So, I eventually decided to try out the new SAC-style tips, and step down to a +75% injector. Brent @ Lincoln Diesel Specialties hooked me up with a set for a great price, and I swapped them in. They came with a basic flow sheet from S&S, and while it wasn't as comprehensive as Exergy's flow sheet, it had the basics.
Here is the old set, vs. the new set from LDS:
Those are legit new bodies, not cores. The manufacturing date on the bodies was from January 2016, and this was in March.
So, WTF happened to this injector?
It looks like it caught fire!?! I thought I might have lifted it, but there was no blowby, and the o-ring at the top of the injector was in tact (though slightly crispy). As a side note, 2 the old injectors had tons of raw diesel in the cups, almost like the tips weren't on tight? No visible diesel in the oil (waiting on analysis results to confirm this), though.
Got it all buttoned up:
Boy, what a difference! Immediately all my idle smoke was gone. I have 16.5:1 compression and a cam with a lot of overlap, so I still get a tiny bit of haze at elevation, but you have to look for it, and catch it in the right light.
Not only was the idle smoke gone, but it is easier to get on top of the turbo, and with less smoke. It also makes more power (by track MPH) than the old set, on the same tune. Which is impressive, because these injectors are smaller...
Day 0
Hours on injectors: 0
Miles on injectors: 0
Miles on motor: 10,796
Miles on truck: 307,032
These are the best balance rates I have ever seen on this motor, so I am not concerned about Cyl#1 being over 2 in park. And with +75% sticks, "only" 6mm3 in park at hot idle seems reasonable to me as well. Mainly, I just want to track the balance rates over time.
Day 17 (today)
Hours on injectors: 28.0
Miles on injectors: 1,138
Miles on motor: 11,934
Miles on truck: 308,170+
Having put a few tanks through the injectors, it appears I get slightly better mileage than with the old injectors, despite driving with a heavier foot. I'll keep logging the mileage and see what it does when I settle back into a routine so I can get a fair comparison. But so far, I am extremely pleased with the injectors.
I'll come back and post periodic updates to see how these injectors hold up. Hopefully the SAC-style tips last as well on the LB7 as they do on the LLY+!
Backstory
Day 0
Code:
Drive Park
BALRCYL1 -2.69 -2.77
BALRCYL2 +1.96 +1.80
BALRCYL3 -0.96 -0.93
BALRCYL4 +0.39 +0.39
BALRCYL5 +0.03 +0.08
BALRCYL6 +0.13 +0.54
BALRCYL7 +0.27 +0.53
BALRCYL8 +0.72 +0.45
MAINRATE 12.3mm3 5.9mm3
Day 17 (today)
