Do you guys think that a s595 would be a better choice than a batmowheel 483?
Would need some more info what your goals with the truck are ?
They are vastly different turbo's to compare with both having situations where they would be a good choice, they very best way is to decide which turbo to use in any build ( single , twins , triples ) is to decide the goals of the truck ( desired HP level , drive ability amount required , ect ) consider some room to grow , budget , and then decide from there , if you still personally dont know what turbo's are needed for your build , with the info above any good turbo guy / shop will be able to help you get the right setup , most will help gladly as long as your buying the turbo's from them , the only thing to be careful of is make sure they have actually ran or tested what there recommending , its alot of money to spend on a turbo setup for higher HP levels , you dont want to be a experiment based on "theory's" .
