Dam.... New they helped.. but not like that
Sent from my HTC6500LVW using Tapatalk
Do you have a set on your truck? I know mine still won't let the engine budge.
Nope. But it will when the motor need built.thanks for the info
1/4" spacer under the trans mount :woott:
That might just do the trick. That would bring the turbo forward a little bit. That would be a lot easier than taking the motor mount off again.
I'll have my lift empty this afternoon if you wanna try:thumb:
What pedestal & spacer are you using? I put GT42 on an LMM using the PPE cast pedestal & spacer & it had plenty of room.
It's a ppe tube pedestal. I'm not exactly sure what spacer it is. When I installed the kit the spacer looked to be about 1.5" thick.
I know this truck. To dent the firewall any more we'll have to take the turbine housing off. That would be fine except when we tried one of the bolts from the housing to the pedestal started seizing up. It was all we could do to tighten it back down. Now it'll break or stay in. No 2 ways about it. Those damn hot side bolts can be a nightmare.
While i understand the frustration that causes, at some point its gunna need fixing anyhow if he ever has to take that turbo off for something else. may as well fix it now, give it a dent and carry on with no more issues
